Hi All,
Since moving into my house 6 years ago I have been having problems with the tile line on my ~ 30 year old gunite pool. One whole section of tile came off a few years ago. I discovered I couldn't get the same tile any more- they don't make it, so I used a section of a similar pattern only larger to patch it. Then a section on one side of the pool developed a crack and shifted out an 1/8th of an inch or so. The tile was still attached solidly to the concrete behind it, so I think the whole pool edge may have been cracked. I've filled it with tile cement and it is holding. Now when I opened the pool yesterday, a whole section of tile came down and I noticed the concrete behind it had deteriorated and crumbled some. A portion of the gunite corner beneath the tile also came off with it.
Question: what can I do about this? I'm tired of replacing tiles as the fall off. This concrete deterioration has me a bit worried and may move this out of the DIY fix realm unless others on here can provide good guidance.
Most of the pool doesn't have any coping stones or bricks, just concrete slabs that hang over the pool edge and are in good shape, so getting access to the pool rim from the top sounds like an expensive proposition.
I'll try to post some pictures later tonight.
Thanks!
-Ryan
Thanks!
-Ryan
