I know this is a perennial topic on the website. I'm considering building a small CMU-based semi-inground pool, for several reasons:
Here's an overview of my plan for this approx. 6500 gallon, shortened kidney pool:
- Gunite/shotcrete (along with virtually all other poolbuilding-related trades or subcontractors), in my area, seems to be extremely locked down by professional poolbuilders. Pools here cost substantially more than in many other parts of the country. I'm sure much of that is due to the expertise; I do think part of that is also due to the intense demand for pools in South Carolina.
- I have some experience with concrete and believe the floor pour (and definitely the wall block placement) is a more DIY-friendly approach than other options such as forms for poured walls. I am also very comfortable with plumbing and electrical.
- My budget is limited, and going with this option seems like I should be able to get a solid pool for less than a good fiberglass shell or gunite pool. I know there are advantages both of those other methods offer, and if I had the funds, I would go with one of them!
- Can anyone speak from firsthand experience about the sanity of my proposed method given what I've explained above?
- Can anyone sharpshoot my general proposed design for the floor and wall structure?
- Floor slab and wall footer poured with vertical wall cavity rebar embedded
- Dry-stacked CMUs, surface bonded, then cores filled
- Waterproofing applied to full inside surface
