compool to aqualink conversion
xclaim494
85
Georgia
Hayward Aqua Rite (T-15)
i have an old compool unit -
link to pdf is above of my complete unit - works great - just no app/wifi control
i want to upgrade to a Aqualink Rs8 - do i need to buy the whole enclosure, power unit or just the board/panel ?
I'm pretty handy and good at electrical work so will be doing it myself.
just need some guidance.
Thanks in advance.
Why do you want to upgrade your Compool to an Aqualink instead of an EasyTouch?
Pentair has a Compool to EasyTouch Upgrade kit.
If you want to change to an Aqualink then you just remove your existing system and install a new Aqualink system.
wow Allen TY Sir : did not know that existed
does that come with the wifi/app addon ? or is that another module ?
they whole idea was to move away from Compool and to a more standard iAqualink approach for wifi connectivity
I also have a Pentair VS pump so this makes sense.
TY again most helpful suggestion
To add WiFi/app to a Pentair EasyTouch system you need to get the ScreenLogic add on.
Figure out all the costs involved in the upgrade and see if it makes sense to just install a new IntelliCenter system that has wifi/app builtin standard.
I recently changed from Jandy RS to Pentair automation after a lightning strike took out parts of it. Pentair is way better in my opinion. Plus they don't cut your warranty to zero for DIY and/or internet purchase.
Alen : Quick question
If i do buy an Aqualink RS8 and convert from compool to Aqualink RS8 , then can i use the same compool transformer and power-center ? or do i have to re-buy the powercenter and the transformer and a whole new aqualink box ?
You keep the Compool Power Center. See the manual at https://www.pentair.com/content/dam...emUpgradeInstallationandUsersGuideEnglish.pdf
The following items are included in the Compool to EasyTouch Upgrade System kit.
  • Compool To EasyTouch Upgrade Kit (P/N 521107) - For upgrading CP3xxx systems
  • Compool To EasyTouch Upgrade Kit with Transformer (P/N 521247) - For upgrading Cp100, Cp1000,Cp2000 system.
  • Temperature sensor with 20 foot cable, o-ring and hose clamp (P/N 520272) - Uses for the water temperature sensor
  • Temperature sensor with 40 inch cable - Used for the air temperature sensor
  • Compool to EasyTouch Upgrade Pool and Spa Control System Installation and User’s Guide(this manual
