- Jun 12, 2023
- 194
- Plaster
- Hayward Aqua Rite (T-15)
So I don’t usually test this often, but decided to today and not sure of my results . After 2-3 drops of the R-003 (I did add the 5 per the test directions) the sample water had an ever so slight pink tinge but it wasn’t pink like the sample after the DPD powder for the FC test that precedes it. I added a couple of drops of the R-0871 and it went back to clear.
So does any slight pink indicate some amount of CC? How do I get the CC to zero?
Also wondering about when I would want to slam or shock the pool? I was discussing pool stuff with a colleague at the hospital and he said he shocks his pool weekly and was shocked that I didn’t and even more shocked that I never had. I try to follow the TFP method and keep my FC on high side of the range per my CYA. I have never had a FC less than 3 even before my SWG got turned on. I test pH and FC almost daily or at least every other day. My water has always been crystal clear too.
Anyway, can you advise if I need to shock my pool given my maybe 0.5 or 1 CC. My FC is 8 today.
I added 1 cup of muriatic acid on Saturday night and pH is still 8/8.1 today . Didn’t check yesterday. Is it ever going to normalize? My Alk is 70. Seems like I will never have a ph below 7.9.
As always, appreciate any feedback/suggestions/tips.
