1. Will get Stenner Pump. My IPh pump is old, probably 5 years, and I don't want to route it through the SWCG power cell. Here's the one I was thinking of:
https://www.amazon.com/Stenner-Pump-85mhp17-Peristaltic-Adjustable/dp/B015OJ74W8/ref=sr_1_3?crid=2Q0D9SS68OSIN&keywords=Steiner+pump&qid=1658584811&sprefix=steiner+pump,aps,95&sr=8-3
Does this pump hold up well to the elements? Is it possible/recommended to mount it on the IPH tank?
Not sure what prompted that decision, but looks like it'll work. Though $360 could be put toward ScreenLogic instead. Once you start using it, you'll wonder how you got along without it. Personally, I'd just use the existing acid pump, and replace it if and when you need to. It might already be a Stenner pump (depending on the age and model of your IpH). If you don't want to tie into the Power Center, you could run the IpH pump from a 120VAC-to-24VDC converter, which will be
considerably cheaper. That could be mounted inside your ET, and then leave the IpH as is, nice and neat and compact. Your existing pump consists of the motor and the pump tube and the rotating wheels. That pump tube is a consumable part and needs to be replaced every year or two. It gets chewed up by the acid. That might be all you need to make that old pump like new again.
2. Will get a saddle clamp to tee into 2" PVC downstream of salt cell. Will connect 1/4" tubing and check valve to 1/2" FNPT in tee. Old tee I will just put a plug in. I could maybe fit a tee and not do a saddle between elbow downstream of SWCG and chlorine feeder.
Saddle clamp should work fine. I prefer the tee, because the saddle clamp relies on a chunck of rubber, if I remember correctly, and I prefer threads over that type of seal, especially outside in the sun and heat.
3. Will wire Stenner Pump to open relay in ET. Will use 4th relay to operate Stenner pump. Currently actuated valve is in 4th aux button. Will take that off an operate by hand until/unless I do step 4. Also, will just provide high voltage power to 4th relay by piggybacking off pump relay. That will be my flow safety.
Perfect. But as mentioned, you'll be able to keep the valve automated, especially if you go with ScreenLogic.
4. I want to either integrate a raspberry pi and get actuated valve automation back, or learn to solder and convert ET4 to ET8.
I don't know anything about raspberry pi. If it's anything like raspberry pie, then I'm in! If you're into custom DIY electronic gizmos, I suspect you'd be able to do some amazing things with the pi. Others here certainly have. If you're more of a plug-n-play type, then go with the ET8 conversion. I did the conversion, and already had ScreenLogic, and I'm mostly happy with that setup. The ScreenLogic app's interface is OK. ScreenLogic on a Mac computer sucks, and won't run on Apple's current OS, as it is still 32-bit software. I have it on an old Mac. Pentair hasn't given any indication it will ever get updated for Mac. If you're on Windows, it's probably fine (I wouldn't know).
I've seen screen shots of what someone here has done with pi and Pentair (I think that was
@rstrouse), and was blown away. Quite envious, in fact. But I have my hands full with my current crop of home automation and pool automation and I'm not inspired to go down that path just yet. I'd be happy to volunteer rstrouse's help if you want to look into it. I'm generous in that way!
