Codes 125 & 194 Jandy® Pro Series AquaPure®/PureLink™ Power Center and Cell Kit - Nature2 Fusion Soft 1400 SWG
Poochsteph
5
Fort Worth, TX
Jandy Aquapure 1400
Our pool was installed in 2020. In 2023, we had the Flow/Temperature/Salinity temperature, and salinity sensor replaced under warranty. Last week, every time I checked the chlorine, it was below 1, but my salt was at 3300. I turned my salt cell up from 50% to 85%. The next day, the system was giving me codes 125 & 194. Clean the cell and lower the chlorine production. We did both, and the codes went away. I just noticed that my SWG has either been in cell-reversing mode or cell-resting mode for an extended period of time. I had the production set to 35%, and when I checked, the chlorine was at zero. I switched it into service mode, changed the production to 50%, and turned it back on. Now it is giving me codes 125 & 194 again. The codes only seem to be present when the pool is in service or time out mode now. The production is less than 85%, and the cell is clean. What is the problem? Is there an easy fix? We were told if it is the sensor again, the replacement that was done last year is no longer under warrant and will cost $1600 to replace.
Our pool was installed in 2020. In 2023, we had the Flow/Temperature/Salinity temperature, and salinity sensor replaced under warranty. Last week, every time I checked the chlorine, it was below 1, but my salt was at 3300. I turned my salt cell up from 50% to 85%. The next day, the system was giving me codes 125 & 194. Clean the cell and lower the chlorine production. We did both, and the codes went away. I just noticed that my SWG has either been in cell-reversing mode or cell-resting mode for an extended period of time. I had the production set to 35%, and when I checked, the chlorine was at zero. I switched it into service mode, changed the production to 50%, and turned it back on. Now it is giving me codes 125 & 194 again. The production is less than 85%, and the cell is clean. What is the problem? Is there an easy fix? We were told if it is the sensor again, the replacement that was done last year is no longer under warrant and will cost $1600 to replace.
Since I have posted this I checked it again and there no longer error codes, but it back in cell reversing and cell resting mode. Pix attached.
