Pool has been opened for almost 5 days. Started slamming and adding CYA right away.
CYA reading was 5 (Leslies)
Added CYA to ~~35 (R0013, Leslie reading was 42). Now, 3 days later 25-30 (R0013. Will test at Leslies, hoping their CYA test result is more consistent than mine)
Slammed according to instructions - to 10, to 12 to 14.
overnight chlorine loss 0.5-1. Yestarday was 1.5 .
Tried to lower TA by lowering PH twice, but PH stuck at 7.6. (I always had high TA, but ignored it)
Added 12lb of CH over the period of 3 days (something I always did much later, when pool water was clean)
Can still smell chlorine
I've been having issues with low CYA upon opening in the past, assumed it was soil bacteria but never tested. Could I be having this same issue again with overnight loss 0.5-1 and CC 0.5?
Current test results (TF100) -
FC 11.5
CC 0.5
PH 7.6
TA 150
CH 240
CYA 25-30
Could old filters be slowing the processes? I have 2 sets, use older ones during opening and then once water is clear replace with newer ones for the rest of the season.
No visible algae, but no improvement since Tuesday.
Thanks.
FC 11.5
CC 0.5
PH 7.6
TA 150
CH 240
CYA 25-30
Thanks.
