Hi! So, my pool water became really cloudy all of a sudden. I checked and cleaned the filter and did a test with that red and yellow liquid. My PH was non-existent as was my chlorine level. I had only been using stabilizing chlorine pucks in the skimmer and algaecide since I did a full shock treatment when I opened the pool about 6 weeks ago. Then, all of a sudden cloudy water and chlorine and PH were at 0! So, I started putting two pucks into my skimmer and about 6 kilograms of PH booster along with the recommended amount of Alka-booster. After a day, the chlorine and PH were perfect (I couldn't test the alkaline), BUT my water was still cloudy. I took a sample to my local pool store where they tested it and the results were: Chlorine perfect (which I knew), PH perfect (again I already knew that) and alkaline perfect (I was glad to know that).
When I asked why my water was still cloudy, the pool store guy said that there must be too much stabilizer and that I would have to empty out 75% of the water in my pool and refill with fresh water. I am refilling my pool as I write this. He also said that I should stop using the chlorine stabilizer pucks and just stick to granulated chlorine treatments. He even said to stop using algaecide. Is this legit? Thanks!
