Russo221
It's an aqua Pro 200 sq 2hp cartridge filter.... I mean the return pressure on that thing seems very powerful... Take your hand off..... But like I said the filter is off to the side so when it goes thru the skimmer it runs about 12 feet of pipe and then it goes thru the filter then same thing going outI believe you are seeing just what I saw - dead algae accumulating on the bottom. It gets less and less as you go forward, and takes a while for it to settle back down after you brush it up and disperse it in the water. I think one of your issues is that your filter isn't very effective, so it is going to take it awhile to clear the suspended debris. (I think I remember seeing that you have a small cartridge filter - if that's not correct, disregard my last statement!)
Sent from my SM-G935V using Tapatalk
