- Jul 5, 2012
- 160
YEGGIM actually I think the floc actually saved us some time. I should of taken a picture of the first day I flocked it. It was like sludge on the bottom of the pool. I spent 3 days vacuuming my pool to waste and each day I added a little bit of floc to it was better each day. so I say kuddo's to the floc for getting it out of my pool. I think I would not be as advanced in the process if I had not used floc. It was the first time I had seen my pool since May when we opened it.
As for not following proper steps before as SUPERTUNE suggested, you have to understand..we have had algae in the past...of all kinds. we had black algae and through patience, store pool testing and pool store chemicals we beat it...so for us to have done that and then spend weeks doing the same process on our own this time and not seeing it work was a huge let down and made us very frustrated. I was also getting conflicting advice in the beginning, even on here, as to what to do and what not to do.
Im not ready to throw in towel just yet. However, I am giving it to the first of Aug and if it has not cleared I will close it for winter. Since we have been working on it for two months at that point if it hasn't cleared..it isn't going to is my opinion. Even after doing our method vs shock method on here. I am ready to try anything anyone suggest...what is frustrating is I have turned off the pump when I did the flocking and like I said spend days vacuuming slowly to waste only to have it end up looking like the pictures b/c it gets stirred right back up.
The pictures you posted are very hopeful but yours was just a little cloudy where as mine is discolored, cloudy and unchanged for months. I do hope to see crystal clear water again. If you all suggest turning off the pump will be good, Ill do that. but then I will spend all day vacuuming to waste and end up throwing out bleach in the process....so im not sure I should???
Im not sure what kind of algae or problems our pool has right now...in the past we have worked on our own pool with no problems..even with algae...never had a problem getting it to clear. that is why we are so baffled this yr...it just will not clear. It's like our pool has some form of water cancer and nothing we do is getting rid of it. Things we have done succesfully in the past is not even touching it this yr. prior to getting an installed above ground pool we had the Intex pools for about 3/4 yrs and even with them..if we got algae...we were able to get rid of it...but like I said..this yr..NOTHING has been able to get rid of it. Nothing. Last yr our water was crystal clear all yr round...we opened in Late April/early may and was swimming all the way up after Sep...day, night you name it. it was awesome....this yr...we haven't swam at all...it's been on headache after another.
so that is why it is frustrating to us b/c we know we have fought it before and been successful and this yr not so much.
getting ready to post new results...
