The FC can be done inside as what you are looking for is the color going from red/pinkish to clearish.
One idea - take a sample from the tap that is your fill water to the pool. It should have minimal Chlorine (<1ppm) and zero CYA. This way you can focus on the CH and TA test. Not sure what part of Florida you are in and if hard water is an issue. Regardless, it just provides you another benchmark for when you add water to the pool.Awsome, tomorrow i do all the test. Then on monday i will have the salt test kit,and the speed stir to help in the process.
I try to do the TA test but the water is not turnning Red. Im watching videos and reading.
What size water sample are you using? Be sure it is 10 ml. Add the water to the vial first to the 10 ml line then add the Stir bar to do the test. Add one heaping scoop of R0870. Each drop of R0871 to clear is 0.5ppm.Help here plz,i
Each drop equals 0.5ppm FC. So 29.5 ppm FC.With 59 drops it clear now what is that result?
Sorry for confusion. You get the same result but I like whole numbers.Does the drops have to be diviided or multiply a little bit confuse.
