MITBeta
- May 28, 2020
- 1,240
- Vinyl
- CircuPool RJ-45 Plus
You do not want to add to 80ppm until you have completed the SLAM Process. For now, get CYA to 30ppm.
There's a very good reason why Marty is recommending "The Party Line" (or is that the Marty Line?) not to raise the CYA until you've killed all the contaminants in your pool. At 80ppm CYA, you'll need to maintain a level of 2.5 times more chlorine for the water to stay at a shock level, which is where the magic happens. Welcome to the forum and good luck SLAMMing!Pool math tells me to put 7 pounds and 8 onces of dry stabilizer to bump up cya from 20 to 80. Am I doing the math right? It will probably take 4 socks on 4 returns then I guess.
I added about 1.5 pounds to a sock and it is now releasing stabilizer..will bring it up to 30 before going to the next step of bringing pH to 7.2..thanks everyone !!There's a very good reason why Marty is recommending "The Party Line" (or is that the Marty Line?) not to raise the CYA until you've killed all the contaminants in your pool. At 80ppm CYA, you'll need to maintain a level of 2.5 times more chlorine for the water to stay at a shock level, which is where the magic happens. Welcome to the forum and good luck SLAMMing!
The reason not to use tabs during this process is they're very slow to dissolve and release, and also continually release trichlor (CYA) into the pool.
Learn more here:
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.www.troublefreepool.com
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.www.troublefreepool.com
Do not effect water chemistry.dirt and sand
