Two weeks ago when I started the TFP journey, I was running a high FC in the 7-9 range. Water was nice and clear. A few days ago I reduced my SWG % from 50-60 % down to 25 and 30%. At noon today, my FC was at 3 and the water is showing a cloudy haze. It’s not bad but it doesn’t have that sparkle. UV has been extreme here in Florida. I assume the low SWG setting is the culprit but I don’t know for sure. I increased the output to 60% so I can get back to an FC of 6.
These are my numbers at noon today. SWG had only been running 2 hours before the test. I normally run for 8 hours/day. I don’t feel I have a good grasp on setting the SWG for consistency yet. The only chemicals I’ve added was about 16 oz of Muriatic Acid last Tuesday to lower the pH to 7.4. It has come back up some.
FC 3
CC 0
pH 7.6
TA 80
CYA 85
Salt 3487
Water Temp 85
CSI -.025
What would you do to clear up the water in my SWG pool? Thank you.
FC 3
CC 0
pH 7.6
TA 80
CYA 85
Salt 3487
Water Temp 85
CSI -.025
