Cloudy water. Need some advice.
Charlie227
90
Vero Beach, FL
Two weeks ago when I started the TFP journey, I was running a high FC in the 7-9 range. Water was nice and clear. A few days ago I reduced my SWG % from 50-60 % down to 25 and 30%. At noon today, my FC was at 3 and the water is showing a cloudy haze. It’s not bad but it doesn’t have that sparkle. UV has been extreme here in Florida. I assume the low SWG setting is the culprit but I don’t know for sure. I increased the output to 60% so I can get back to an FC of 6.
These are my numbers at noon today. SWG had only been running 2 hours before the test. I normally run for 8 hours/day. I don’t feel I have a good grasp on setting the SWG for consistency yet. The only chemicals I’ve added was about 16 oz of Muriatic Acid last Tuesday to lower the pH to 7.4. It has come back up some.
FC 3
CC 0
pH 7.6
TA 80
CYA 85
Salt 3487
Water Temp 85
CSI -.025
What would you do to clear up the water in my SWG pool? Thank you.
Shapmaui
51
Kihei HI
I am sure you will get the answer you are looking for in this forum. My initial thought is your FC is too low for the amount of CYA you are reading.
Please take a look at the FC/CYA chart here-
Charlie227
90
Vero Beach, FL
Charlie227
90
Vero Beach, FL
Yes, I agree with the low FC.
Charlie227
90
Vero Beach, FL
Update:
After my previous test, I bumped the SWG to 60%. After 6 hours, I was back up to FC 4 even with all the brilliant sunshine. The pH went down to 7.4. I had 3 folks in the pool most of the afternoon. I am going to run the pump all night and set SWG at 50% and see where I am in the morning.
Charlie227
90
Vero Beach, FL
Update - Ran pool pump all night. SWG set at 50%. Water is beautiful and crystal clear this morning. Will leave it set and do a full water test this evening.
FC 6
PH 7.8
Salt 3493
Water Temp 81
Charlie227
90
Vero Beach, FL
I did the OCLT this morning. Last night the FC was 6 and this morning it is 5.5. Looks like that is ok and my previous cloudy water was the result of letting my FC get too low (3) considering my CYA level.
Thanks for all your good advice. Much appreciated.
Reactions: justinc
