Cloudy water/high cya
blondestar1616
67
covington ohio
My test kit is missing a couple elements from last year so I dont have every reading;/ but I have cloudy water. Its turquoise not green but I cannot come close to seeing the bottom.
Mu question Is, I assumed the cya was 0 since it sat all winter. I used the formula and added the correct amount to get to about 40 ppm of cya. However it is testing st about 70 :/ I've done the test several times and still got 70, but I have been SLAMing for a few days. Is the cya likely that high or is the results skewed due to adding chlorine ?
My ph is reading 7.2
mknauss
22,974
Laughlin, NV
Chlorine does not effect the CYA test. Adding CYA to your pool without a test prior was not a good idea.
You will need to SLAM based on a 70 ppm CYA or exchange out some of your water for fresh.
blondestar1616
67
covington ohio
It was always my understanding that the cya after it sitting for the winter would be zero ? But maybe I remembered incorrectly.
Either way, i was able to get some more readings!
FC 11
Cc 0
Cya now read as 50 ? And I did it two times ?
Water is still very cloudy
mknauss
22,974
Laughlin, NV
CYA does not always go away during winter.
Are you doing your CYA testing under the same conditions each time? Be sure it is in full sun, your back to the sun, vial at your waist, etc.
You should take your FC to SLAM level and maintain it there until your water is clear.
blondestar1616
67
covington ohio
Ok! Today was not as sunny as it was yesterday when I tested but yesterday Idid test as u said today we dint have so much sun :/ but if it comes out later i will try it again. Is there any other reason that would cause cloudiness ? We are still at SLAM levels and have been since Tuesday
mknauss
22,974
Laughlin, NV
Is this water new or carry over from the past?
What was the algaecide? Brand name, best is the ingredients.
Algaecides are rarely necessary. And do nothing for eliminating algae.
blondestar1616
67
covington ohio
This is water from last year, just topped off this spring.
Algaecide was hth super algae guard 60. Alkyl and dimethyl ethylbenzel ammonium chloride
