Just replaced liner on April 6th.
My well water is high in iron, had water trucked in, unfortunately had to use 1500 gallons to start setting vinyl, before truck arrived. Added 3 trichlor tabs and 1# shock. 24 hours later,starting chemistry; water temp 62
FC: 2
TC: 2
TA: 39
pH: 6.8
CH: 53
Added 15# Baking Soda
Next day (4/8)
FC: 1
TC: 2
TA: 90
pH: 7.5
Backwashed, came out dark/rust brown. So, with the addition of well water and residual iron in my plumbing, added 50 ounces of Proteam Metal Magic, plus CuLator pads in skimmer/pump baskets. Added 3 more trichlor tabs. Trying to keep chlorine low, Metal Magic works best with chlorine about 1 ppm.
Performed normal pool maintenance daily, brushing, adjusting chlorine. 2# CYA additions (4/13, 4/18)
4/22
FC: 1
TC: 1
TA: 80
pH: 7.2
CH: 50
CA: 43
Filter pressure up 25%, backwashed, topped up water level, using resin filter to remove iron from fill water. Added 32 ounces liquid bleach, and 4# Proteam Calcium Up
I'm done with the metal sequesterants for now, I want to get my chemistry numbers where they need to be, so I can add borates as a pH stabilizer.
Questions;
1. Pool liner paper work recommends TA 100 and CH 100, is that set in stone?
2. Backwashing, it's my understanding, the only time I need to is when filters pressure exceeds 25% of it's normal operating pressure. Not weekly, bi-weekly, monthly, only when pressure dictates, right?
3. As for borate additions, if I need to adjust CH, should I do it before or after I borate?
FC: 2
TC: 2
TA: 39
pH: 6.8
CH: 53
Next day (4/8)
FC: 1
TC: 2
TA: 90
pH: 7.5
4/22
FC: 1
TC: 1
TA: 80
pH: 7.2
CH: 50
CA: 43
Questions;
