For a couple months, my salt reading on the CP has been significantly lower than the reading at the pool store.
Example, last week reading at Store was 3500ppm, on Hayward Blue Essence shows 2600
The 2600 reading causes the check salt and Inspect Cell Lights to flash
Its still generating chlorine but I guess at lower rate
I've had the unit 3 years
Last week, I ran the system off for about 18 hrs, then auto for 24 hrs, The levels did come up to 2800 which gave me a couple days of error free lights (check salt & inspect cell)
Now, the last couple days, the salt on CP is back down to 2600ppm, and the lights are flashing.
I took salt cell to local pool store, ran a test, everything checked out OK? I wonder if it was the control panel?....but when I do all the tests to measure the salt levels
(Off>Auto>press diag button 5 times>system starts measure ppm>Auto>SuperChlorinate) it works fine, no issues??
Is this salt cell or CP?
