- Mar 20, 2023
- 250
- Vinyl
- CircuPool Universal40
Circupool Universal 40 SWG
It is reporting 2300 PPM on the screen, and flashing the low salt light, or even leaving the light continuous which means it thinks that there is too little salt to generate, along with the check cell light and "Slo" on the display which I think means "Salt low."
I did pop the cell off and took a peek in there. There seems to be a small seed in between a couple of the fins, (Tried to get it out with a popsicle stick, but ended up pushing it further accidentally!) But otherwise it looks good in there.
When I put it together at the beginning of the season, I did acid-clean the cell as described in the instructions as it had a little bit of build up. That was at the beginning of my TFP learning and I believe my CSI has always been in range, and below zero.
I just measured salinity with my kit and it is 4000 PPM.
Is there anything else I can try?
We bought the house in December so this is all relatively new to me; if I recall correctly, the sellers told me they installed the system in 2017 or 2018. So the cell is likely a few years old.
