- Jun 24, 2021
- 15,889
- Vinyl
- CircuPool RJ-60 Plus
If you don't have a cover and you get some sun, assume that you are using 3-4FC per day.Can someone point me in the right direction of now transitioning back to me SWG and make sure its properly set to provide enough FC?
Use pool math to figure out a run time and % output to make 4FC. When your FC is just above the top of the range for your CYA, turn the cell on and run the amount of time and % output you figured out with pool math.
If your FC rises, turn down the run time or %. If your FC falls, turn up the run time or % output.
All you want to do is maintain your FC around the top of the range for your CYA.
