- May 3, 2014
- 62,687
- Fiberglass
- Pentair Intellichlor IC-40
Thanks!Not enough to alter the issues you have. You’ll need to SLAM.
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.www.troublefreepool.com
Right. I drained a bit of water and added the other day, and we also got tons of rain yesterday, so I had to lower the water level almost 2 inchesIt's late in the day here, and not nice out.
The CYA rest needs overhead sun for best results, so get us a solid reading at the first convienence that you're home mid day when it's sunny.
For now, the 70 CYA is ballpark-ish enough to use and at least we know it's not 200.
So to SLAM, I need to add enough liquid chlorine to achieve my SLAM level of 28, and then keep adding the liq chlor to maintain my target FC of 8? Does that make sense?Right. I drained a bit of water and added the other day, and we also got tons of rain yesterday, so I had to lower the water level almost 2 inches
Lower your pH to 7.2-7.5 first.So to SLAM, I need to add enough liquid chlorine to achieve my SLAM level of 28, and then keep adding the liq chlor to maintain my target FC of 8? Does that make sense?
No. Time is of the essence. The sooner you start, the sooner you finish.Does it matter what time of day I start the SLAM?
Sure.Should I run my Dolphin cleaner while slamming?
So I waited 2 hrs and tested my FC and it was 53.5, and my SLAM level is 28. What should I do know?No. Time is of the essence. The sooner you start, the sooner you finish.
I just tested it again, so at the 4 hr mark since adding the chlor and FC is 44. How long do you think should wait to test again?Test it after a few hours.
Check your calculations on adding. Seems you over added a bit.
So it dropped roughly 10ppm in 2 hrs.I just tested it again, so at the 4 hr mark since adding the chlor and FC is 44. How long do you think should wait to test again?
