I just started 4 hrs ago. Water was pretty clear already when I startedNo need.
What stage of SLAM are you in? Is the water cloudy? Green?
I can imagine. I used the Pool math app calculator and put in what it said.OK --- just let things settle for today. You can test this evening or in the morning.
No more going way past SLAM FC level. Your liner will not like it.
Need to figure out where the discrepancy came from before adding your next dose.I can imagine. I used the Pool math app calculator and put in what it said.![]()
Last night at 10, the FC was 39ppm, and I just tested again now, at 8:30 AM and it didn’t change, still 39.I can imagine. I used the Pool math app calculator and put in what it said.![]()
What did you enter into Poolmath? How many gallons of LC did you put into the pool?
26K gallon pool should take about 7 gallons of LC to go from 0 to 28ppm. To get 54ppm you would have put in double that.
Also what exact steps did you use to test?
10ml sample size with 1 scoop? How many drops of R-0817? Divide drops by 2 to get ppm(assuming 10ml sample)?
I used a 10ml sample and had to put in 107 drops of R-0871 to one scoop of R-0870.
When I initially tested for Chlorine, the sample didn’t turn pink when I added the R-0870 powder, so I assumed that meant the Chlorine level was 0??? So, because it never turned pink, I assumed that meant that the FC was 0 as well, because it was clear? Then, I did the CC test, and after adding the 5 drops of R-0003, the sample turned pink. I then had to add 6 drops of R-0871 to get the sample back to clear, resulting in a CC level of 3??? And a TC of 3.Your data is not adding up. I would check all the data you have entered into Poolmath, your testing procedure, etc.
I used the 10% 5 days before the SLAM, then switched to 12.5% strength for the SLAM because it was more economical.How confident are you in your pool volume? What are the dimensions, shape, and depths?
This isn't enough to make it off that far, but are you using 10% or 12.5% LC? Your notes show 10, but your effects of adding show 12.5.
Yes, using the Smart Stir.That wouldn't change it that much if at all. It's rectangle? Depths from 4-6.5ft get my calculation near 25K gallons. Just trying to find anything that could make that much difference.
Are you adding drops slowly, about 1 per second. Letting it fully form before dropping and not forcing them out too quick?
Just not sure what to do next. Wait how long and rest FC again? Test the CC again? Do a full battery of tests again? Thanks for all of your help!Yes, using the Smart Stir.
