Can You Help Me?
Salt does not go away ... it is like CYA and only lowers with physically removing the water from the pool. And, realize that all forms of chlorine are also adding salt back into the pool.
That said, taste is subjective, and every one's sensitivity to salty taste is different.
Ok Thanks! I have it running so glad I didn't have to add more salt this year! Good to know! I still have a little cloudiness, but there was so much dirt in the bottom from all of the rain we have had. The more I vacuum the clearer it gets! Thanks for all of your knowledge and help!
mimidjets,
Were you able to test your CYA so you can provide us with that number? I presume you're still shocking until you meet all 3 criteria.
That being: Water is clear, CC equal to or less than 0.5ppm & an OCLT shows a CL loss of 1.0ppm or less.
