So glad to hear that you're beating it and finally seeing some visible results. Yaaayyyy!!
Tip: With those Intex cartridges, nylons are your friend. Slip 2 of the cheap'o 25 cent jobbies from Walmart (2/egg) over the cartridge itself. Make one end so they're both closed toes and taut over the impeller intake hole at the bottom of the housing, helps to catch junk the filter pleats let through.
The nylons catch more than the carts do and they keep things like bugs, grass, hair and other stuff out of the pleats. So cleaning them is easier. I just keep reusing them over and over till they get holes.
Keep in mind that filter cartridges work off of the cake principle. Whereby they do not clean as well when fresh and clean, but once a thin layer of crud starts to build up, they then trap smaller and smaller particles as they filter better. I used the return line as an indicator for when to clean the filter, once the flow noticeably reduces, I clean it.
Also, due to the bad design of the filter, it likes to primarily filter on one end of the cartridge and one side of it. So by rotating it about 45 degrees as well as flipping it end over end, you can get more run time out of it between cleanings. I also lift the cartridge housing up above the water line when changing it, so as not to let water flow out freely from the pool. But, once I get the dirty cartridge pulled out, I lower it below the waterline, turning it upside down to let fresh water flow out for a moment. Then I flip it back around, finishing the swap and buttoning it back down.
Thus rinsung out all the dirty particles and junk in the cart housing so it doesn't all go back in the pool.
I also bleed it 2x. Once before 1st restart, then run it for about 5sec and shutting it off and bleeding it once more. Sometimes between both bleeds, lifting the hoses, hand over hand, coaxing along any bubbles toward the pump on the intake side and doing the same on the return. In some cases I find it necessary to give it a few swift smacks to the hose, but not super hard, but a good SHAKE to release the bubbles from the corrugated ribs in the hose which slows down the flow.
Lastly, those pesky intake and return screens like to clog on the intake side from things that slip down the outside of the skimmer basket. They restrict flow too! So you have to check those from time to time or they'll plug up and let air in through the fittings. I just knocked them out with a dremel tool on mine. Sooo much better. Higher flow too.
Hope that helps.
