Round 2: So we are at that exciting stage, where we are (almost) ready to sign the contract, but before we pop the champagne, we need your superpowers to give this bid a final look-over.
Virtual confetti cannons for the most fantastic reviewers and this forum!
Excavation:
Steel:
Gunite:
Plaster:
Pebble or quartz plaster included. To be chosen by the homeowner
Plumbing:
Equipment
Pool pump VSPHP270DV2A
Automation system IQ904-PS
Filter CS200
Heater JXI400N
Lights IWC15W100
(they gave us option for all Hayward or Jandy, we picked Jandy based upon responses from this forum) & the above is the equipment list they have included
Warranty
Disclaimer:
We include up to 4 pallets of new sod and in the event that the job takes more than 4, the customer will be billed for the extra sod at $500/pallet We build most pools and spas within 30 days from excavation day; however, external factors could sometimes delay the completion of the pool by one or two weeks, or sometimes more. Such external factors could be but are not limited to, excessive rain, delayed inspections, change orders, delayed customer payments, the construction of other features like outdoor kitchens and cabanas, and others.
If the project includes a salt water system, please be aware that we should first start the chemical balance with chlorine tablets and add the salt approximately 4 weeks later, this period is normal and does not affect the completion date on record.
Payment:
Total price $115k
(Hold 15% = 17k until after water)
Data | Pool lengh (Longest) 37 ft | Spa lengh (Longest) | 8 |
Pool Width (widest) 17.0 ft | Spa Width (widest) | 8 | |
Pool perimeter 107 lf | Spa perimeter | 22 | |
Pool surface area 573 sf | Spa surface area | 32 | |
Pool Depth left 4 ft | Spa Depth left | 3 | |
Pool Depth Middle 4.5 ft | Spa Depth Middle | 3 | |
Pool Depth right 6 ft | Spa Depth right | 3 | |
Pool form: Geometric |
Excavation:
3/8 Inch steel rebar on 8 inch centers, both ways |
1/2 Inch steel rebar x 4 on raised bond beam |
3/8 Inch rebar, 16 inch on center concrete deck |
Steel:
Dry mixed Gunite rated to exceed APSP building standards |
12" Bond beam, 6 to 8 inch walls and floor |
Gunite:
Plaster:
Plumbing:
Pool pipes to be up to 3 inch schedule 40 PVC |
All main drain to be ANSI/APSP-16 2017 VGB Compliance |
6 pool returns and 2 spa returns | ||||||
6 spa jets | ||||||
Independently plumbed skimmers for added performance | ||||||
The spa will have a dedicated air line | ||||||
An automatic fill line system will be i | ||||||
An overflow system will be installed | ||||||
All gas lines to be run and inspected Tile and coping:
Equipment
Filter CS200
Heater JXI400N
Lights IWC15W100
Yes Hayward Tristar VS Variable speed pump |
Yes Pentair Superflo feature pump |
Yes Hayward cartridge filter |
Yes Hayward heater, or Rhem for the 400 BTU heaters |
Yes Hayward automation system with OmniLogic mobile app |
Yes Hayward ColorLogic 320 LED lights for the pool |
Yes Hayward ColorLogic 320 LED lights for the spa |
No Hayward White Pool Light |
No Hayward White Spa Light |
Yes Hayward actuators |
Yes Hayward chlorinator |
No Hayward Salt System |
Yes Jandy 1 HP spa blower |
Note: Upon customer's request, we may use the equivalent equipment by Jandy |
Warranty
Gunite: Limited Manufacturer Lifetime Warranty | ||
Plaster: Limited Manufacturer Lifetime Warranty | ||
Equipment:
Workmanship Limited 3 Years Warranty |
Disclaimer:
Payment:
Total price $115k
