If you have to drain some, just get a sump pump from the hardware store. Much easier and safer and you can just direct the output hose where you want the water to goajw22---good point. guess it depends how fast the water comes out. i have a drain about 10 ft away that the water should flow into.
side question---if i dont drain the pool and just start adding liquid chlorine, wont water evaporate gradually, thereby reducing the water as well?
That is about the high end of what Leslie can test.115 according to Leslie Pools. will get it tested tomorrow again.
