- Jun 1, 2018
- 16,019
- Vinyl
- Hayward Aqua Rite (T-15)
If your friend has a swg & has an ongoing algae problem then he has to fix the original cause as well as slam the pool. That involves some work + investigation when the hard work is done. Many people are content with the results from the slam & do not care to pursue the reason they needed one in the 1st place. When algae comes back they say the TFP method doesn’t work when in reality the SLAM Process is only 1 part of TFPC the premise is really attention & prevention.
It could be several things, bad (dying cell), scale, lots of splashout, lots of rain, or a leak that allows cya & salt to get too low (an autofill can mask a leak) (an overflow drain can conceal dilution from heavy rains). Until your friend really wants pool freedom for himself- you will be his “easy button” if u allow it & yes, it will absolutely exhaust u.
I am in the same boat as Kato- some people are inconvincible & some must get to rock bottom before they see the light.
I just enjoy my sparkly pool & carry on.
