Can anybody recommend an 50amp 240v outdoor timer to control my Hayward HeatPro 140,000 BTU heat pump?
Here's my dilemma:
I was running a single speed Pentair pump on an Intermatic T104 timer (240v, rated for 40 amps) and I'd turn the pump off when it got dark, and the heater would go idle at the same time since no water was flowing through it. Really no reason to keep the heat pump running while it's dark anyway.
I've since replaced my pump with a Pentair Intelliflow3 variable speed pump, such that I can run it for 24 hours (better water quality) but kick it down into low-flow (20gph) for all of the evening and overnight hours. (I run it at high speed for a couple hours in the morning, "medium" speed around 30gph until early evening and then low speed over night)
So I'm no longer using the timer, but the problem is, at 20gph, the heat pump will go on and off, in and out of the "low flow" state (sometimes it'll stay on, often it kicks on and off which I'm sure isn't good for it.)
So in the absence of an expensive automation system, I wanted to put the heat pump on the timer I have and just program it to coincide with the programming of the Pentair variable speed pump. The heat pump though is on a 50amp circuit, the timer is rated for 40 amps. I've tested the heat pump circuit using an ammeter and know that it never actually exceeds 25amps during initial startup draw or while running, so I'm sure it's safe, but I worry could fail an inspection. I'm not finding any 50amp rated 240v timers though, surely there must be something reasonable? Or maybe I just go with what I have...
Here's my dilemma:
