MSchutzer
Yep, just remove the 240vac connections from your timer contacts and replace it with the two contacts from the heater. The timer would then switch the contact closed to enable the heater.I'm having trouble visualizing what that looks like using just the 240v timer I have now. Aren't those external switches 24v? So I'd set "spa" temperature where I want the pool to be at and then toggling the Pool contact would turn it on/off?
The timer runs off AC voltage so you need to make sure that you actually can get a pair of isolated contacts on your timer to use.
