I just noticed the CH recommended levels here on TFP changed recently. With the delta between low/high of 450, I'm not too sure what my target should be. Should I pick any number between 250-650? Like the mid range ok? My test results as of 5 minutes ago:
FC 4
pH 8.0+
TA 120
CH 230
CYA 40
My TA is a little high is bc I added alkalinity up since I was always chasing my pH.
Also is it true that I could only add 16lbs of Calcium hardness at a time and should I pre dissolve it prior?
FC 4
pH 8.0+
TA 120
CH 230
CYA 40
