We opened our pool this spring at the beginning of April and found heavy calcium crystals on the walls and floors. The plaster was completed on the pool July 20th 2020. The service tech has been using the Orenda process to balance the LSI (Calcium Crystals vs. Scale) after researching the problem to help solve without hopefully having to do an acid wash. They have also discussed with Diamond Brite and agreed upon this approach along with using Jack's Magic Magenta Stuff. The goal is hopefully after 6 weeks of balancing the LSI and using the product it'll dissolve the calcium crystals. Interested if anyone else has experience with this problem and the best solution. Yesterdays test results along with results from 4-12-21 and the desired levels are also shown in the attachment. Appreciate any insight.
4/12/2021- Tests and Desired Levels
4/22/2021- Tests and Desired Levels
