Hello All!
Happy Summer heat wave! :sun:
I have a random question about what is "normal" or what I should expect after adding MA for pH control.
I have noticed a couple of things after I add MA to my pool...1) the slight calcium line around the periphery seems to diminish (which is just fine with me as I have actively been working to reduce it) and 2) I notice there are chunks of calcium (nickel to quarter sized) that seem to come from the plumbing lines and settle on the bottom.
My ? is mostly about those chunks...does the MA "soften" any hardening in the lines and is that what is flushing out? and is this "normal" or something I should worry about?
Also...over time...would simply adding MA help reduce the faint scale mark at the waterline or do I need to be more aggressive?
I have worked to remove quite a bit of the scale already, probably a good 90-95%. Because it looks so much better I haven't been as aggressive at removing the last bit...I LOVE the thought that simply adding MA for pH over time will eliminate the rest...AND YES, I know I'm being lazy...but it is summer!
Anyway...just wondering if others have had this experience when adding MA?
Thanks in advance for your stories/experiences...happy swimming!
Forgot to add my numbers...CH runs around 850 but I live in an area with high calcium in the water so there's not much I can do about hardness...that's softened water.
