I have a hot tub that hasn’t been ran in years. The original home owners said it only needed the heater replaced. I found out the pump was no longer working after I changed the heater and it has sat since then. I filled it a couple years ago to see if it leaked. It did. From around the light fixture, maybe a couple jets.
The finish seems to be in really good shape since it has been stored dry, under an insulated cover.
However, I can see myself having to change all the plumbing, pump, heater, control module, head rest pads, maybe even the jets. The surround/base is completely shot, I‘d have to build a new one.
Trying to weight the cost difference between buying new vs rebuilding this spa. Anyone have a rough idea on costs to replace the components vs buying a new similar size spa? I like projects but if it’s going to cost half the price of new then it may not be worth it.
The control module seems to run on pneumatics? Are the new spas controlled the same way? Seems like there are several areas where I can upgrade/modernize during the rebuild.
Thanks, Shell
Thanks, Shell
