- Sep 8, 2021
- 241
- Plaster
- Hayward Aqua Rite (T-9)
Just caught up my reading on your thread. Looking good!Well it was a 3 week delay to get green on pre gunite with rain delay, a leaking check valve replacement and having a bonding step needing done with a backorder nut.
But we are now here and await shotcrete schedule.
Also all our tile and stone is on hand in the garage.
We went to NPT tile in Tempe. We are using RVCA Tile for all the tile work, stone on the pillars, mosaics, coping, and interior. Plus probably some other stuff. They have been great.Just caught up my reading on your thread. Looking good!
Where did you get your coping and tile? I like the 1x2 glass tile (but we'll probably get 1x1 because that is what my wife likes) and I really like the waterline tile you picked out.
Thanks Nikki! I'll make sure to check both out.@thewolf56 If you go to NPT make sure you also go to Noble. They are across the freeway from each other. I thought I would like NPT best but ended up looking Noble.
It is very common and you got off very lucky in that is all that fell. There is one where the whole wall of dirt AND rebar came down!!!Is this common and the shotcrete crew does some pre prep?
Thank you...I assumed as much lolIt is very common and you got off very lucky in that is all that fell. There is one where the whole wall of dirt AND rebar came down!!!
You do need to remove the dirt so there is space behind the rebar for the shotcrete to encase the rebar. I would get some gloves and start seeing if you can pull the dirt out. Do not try to pack it back in. Just get the loose stuff up and out. The shotcrete will fill in an extra areas left by the fallen dirt.
I would NOT count of the shotcrete crew doing any real prep work. That is the job of the rebar people and now you as the "owner builder".
Kim![]()
We had a few small places where the dirt fell into a pile underneath where the lighting rough-ins were dug. Our consultant told us that the shotcrete sub should clean it out, but I should go ahead and clean it out myself. Luckily for me, it is only 4 spots that will not take much effort.Thank you...I assumed as much lol
After our rains a bit ago, one of our corners had a bunch of dirt fall. In that corner the dirt is now up against the rebar in areas. I did some cleanup. Also, as we did backfill, dirt fell onto the baja shelf and is up against rebar.
Do I need to remove and fix all that? Get it back to three inches between dirt and rebar? Is this common and the shotcrete crew does some pre prep?
Definitely will paint them. Good advice.Don't forget to paint those 3/4" water pipes to prevent the sun from baking them. Use an acrylic based paint. The blue handle ball valves will eventually seize and need to be replaced. When you need to replace them, consider using brass ball valves and copper pipe anywhere above ground - a bit more expensive initially, but you will only need to do it once.
Who was your shotcrete crew?Our shotcrete crew went thru and took out all the clumps and made sure everything was how it should be. There was a part in the deep end wall that they dug out quite a bit of dirt to make it just right. We had a great shotcrete company. They even came back out and added more to our spa floor because it was way too deep and didn’t charge us a minimum.
