It's our first year closing down our pool, so I had the pool company that built it come and do the honors.
They're using a new type of blow-out plug called a "bungee plug" (Bungee Plug A product of Aqua Group, LLC.) - they told me it was their first year using these. Basically, it replaces the eyeball in the pool, and then there's a hole in the center that's plugged with a rubber stopper that's held in place by a strap coming off of the back of it. When you blow air through the system, the strap stretches allowing air to exit. As soon as the pressure is removed from the backside, the strap contracts, and the hole is plugged, sealing the return from water.
I'm wondering if there's anyone that has used these in the past...and looking for feedback. I'm a little nervous, because after the lines were blown out, air bubbles were coming up from the plug. In my mind, the only reason that there would be air bubbles is because the air inside the dry line was being supplanted by water getting into the line...
Here's the picture from the website that probably explains this better than my explanation:
