Certainly not the way I was taught, in a deep freeze area I will use my system, it gets out 100% of the water. Water and -20 scares me.
A small amount of water left in the pipe shouldn’t be a problem, as there’s plenty of room for ice to expand should it freeze.
If the Cyclone is a blower, it’s essentially just a fan blowing a high volume of air so there should be no issues ‘dead heading’ it. Even if you were using a compressor, if you set the regulator properly, the compressor will shut off before there is any damage to the plumbing.
The biggest problem that I see with this plug is that sooner or later the bungee is going to lose elasticity. Once that happens, if the plug is under water, that the water will run back into the pipe... defeating the entire purpose of blowing it out and plugging it in the first place.
I think I prefer something with a more positive seal.
-Chris
- took several attempts for me to get them to seal.
Can you please explain the process, what you did, how you did it, and what plugs you used for them not to seal on the first go around? Thanks!
I removed the eyeballs, pumped air through the lines with an air compressor set to about 10 or 15 psi, then installed expansion plugs. They seemed to have trouble sealing the threaded fittings and would continue to bubble.
The weight of the water will push it closed regardless of the bungee - think of a door slamming shut in the wind. I'm more curious as to how the rubber holds up over a few winters, and how good of a seal it maintains on it's own seat.
I am assuming that you eventually tightened them even more, the bubbling stopped? If not, is this the reason why you switched over? Thanks!
C'mon yourself. It's just a check valve. It's pressure differential that opens it or holds it closed, not the rubber band.
