Hi all, I am 7 days into a SLAM but haven't identified the problem brownish red spots on the floor of my pool, which brush off easily. I thought originally that it was a bacterium (red slime algae) but it didn't seem to follow everything that I read about it (wasn't on the walls, steps, return or skimmer, just the floor). I did have a single spot show up on the pool wall recently and it felt puffy, a little slimy and possibly had some grit which probably isn't possible. It reminds me of a soft crayon. These spots are quarter size or smaller usually and some are thin lines, so I haven't been able to take a decent picture. When using LC the coloring doesn't change. When I used Cal Hypo (Still had some and the CH is low) the color changes to a gray and after continuing to brush, they will continue to return getting darker over a couple days. I pulled my steps out and left them on the deck for a few days and when I took them apart, they had pink inside (Could this be the answer?). Before I started the SLAM I drained 1/3 and then 1/4 of the water to lower the CYA. The O-ring on my filter failed and it didn't run for those 2 days, amazingly I never saw a spot appear those days. I wasn't sure if adding public utility fill water had something to do with that but when I started running the filter the spots were back. I've played with the circulation, and the spot locations move. I'm new to testing and my most recent tests are FC = 18.5, CC = 0.5, PH = 7.4, TA = 80, CYA = 40, CH = 175. Also, I haven't been able to pass an OCLT and I put a new cartridge in the filter. It doesn't seem to be pollen (low spots aren't filling) and I'm wondering if it's a Brown / Mustard Algae? My SLAM doesn't seem to be progressing, and Pool Owner Patience is running thin. Thanks in advance for your help/guidance.
