How do I do that? Sorry brand new to this. It feels like there’s chlorine in it.There is no chlorine in the water.
Post a full set of test results from your kit.
That is not a good sign. A pool that smells like chlorine typically has a chemistry problem.I mean it smells like chlorine
That was from before my pool was built. I was just messing around to see how it works. Maybe it doesn’t smell like chlorine. I could just be my mind.That is not a good sign. A pool that smells like chlorine typically has a chemistry problem.
Is your builder in charge of chemistry maintenance still? How did you get the test data I see in your Poolmath logs from a while a go?
thank you. What shade of red am I looking for? In the beginning it seems purple.Do the full test following the laminated instructions in the kit. For TA test make sure you wipe the tip of the bottle with a wet paper towel before each drop to get an accurate reading, this should also be in the instructions.
You only need to do it for first few tests, after that there is no need to wipe the tip.
Post a full set of tests here, then the experts can help you better.
Thanks. What shade
Do I need to also test for hardness and cya?
In your kit is a laminated card. Follow through that and do all the tests. If the builder has not added any CYA/stabilizer/conditioner, no need to test for CYA.
