Can I run the pump while that is all out so that tomorrow I can put it back in after?
Well it doesn't matter really what it says, I already have a new gasket and the light works fine so I just need to put it back together and in the pool. Which I can do later but in the mean time can the pump be run?The new bulb that was purchased won't work.
There is part of the label that is not visible in the pictures. It has more information, like volts, watts and model number. Can you post a picture of that information on the label?
