Hi all,
I recently bought a home that came with a 15x30' inground pool. The house had been a previous foreclosure, and the owners took some of the pool equipment with them--including the filter which was removed by sawing off the PVC pipes. The house was cleaned up a bit and flipped, but the sellers did not do any work on the pool and left it unopened and inoperable. I did my best to judge the condition of the liner and other items I could see without having equipment hooked up, but in the end it was a bit of a gamble. I knew I'd have to get a new filter and other equipment, but I couldn't tell the condition of the liner or underground pipes.
I got a recommendation for this site and read through the Pool School eBook to learn everything I could for a first-time pool owner. I had a few local pool service companies come by and provide estimates to get the equipment installed and pool opened, even though it was late in the season here in New Jersey. (I figured I'd want to have a usable pool, if only for a month and to not let it sit with a bunch of leaves and green water all winter.)
We have young children so on moving day we had a Baby Barrier safety fence installed. Easy enough, and a few days later the local service guy came to install the new sand filter (decided it was the best balance of cost/performance), SWCG, and replace some aging PVP pipes and valves. We had thought the Hayward 2HP SuperPump was totally shot, but the installer was able to get it working with a little attention to the seized up internal parts. Removing the temporary "cover" (really just a cheap tarp), we found the pool water totally green and with an inch of black leaves at the bottom. He got to installing the equipment and then began the job of vacuuming the debris with an external pump.
A few hours later, I couldn't believe the difference! The green water was now clear, exposing the beautiful vinyl liner and the water circulation looked strong. I let the pump run overnight and the next day, I used the cheap test kit from a local store to get a reading on the FC. To confirm my findings, I took a water sample to the store and they said that we were good to go. That afternoon we were swimming, about 24 hours after starting with a dirty green swamp!
I still have a long way to go to get comfortable as a pool owner but I'm looking forward to the help from the wonderful TFP community. Thanks for reading!
Before: The deep end
Before: The shallow end
(I tried to insert some in-progress photos but it seems I exceeded my image quota.)
Before and after:
Before and after:
