- Jun 24, 2021
- 15,931
- Vinyl
- CircuPool RJ-60 Plus
Yes, but generally I meant, if your backwash wasn't hard piped, and you had a hose, you can see if there was water leaking on filter. That would mean the MPV likely needs a new spider gasket.
Again, it could be a seal/o-ring that is bad, laterals or standpipe that are cracked, or the MPV needs to be rebuilt with new spider gasket.
Tie a sock on the closest return to the pump and see what you get...
