botched replacement safety cover??
wireform
In The Industry
Aug 15, 2017
2,007
Spring Valley, NY
At each of those points there should have been a double strap one from each direction. For some reason they designed it having only one. If you follow sort of the green line and put a anchor, it'll almost accomplish what a double strap would have done just using one point.
abfab
136
Ontario, Canada
What is a double strap?
JamesW
23,524
The straps are an extension of the webbing. They are not added on after the fact. The cover would not be safe if the straps were not aligned with the webbing.
JamesW
23,524
As much as possible, every webbing should have a strap at both ends as an extension of the webbing.
Who made the cover?
abfab
136
Ontario, Canada
Thank you everyone. I've contacted the pool store who will be following up with the manufacturer. They thought it was odd that they weren't contacted about any design changes. Will keep you posted.
Reactions: Leebo and JamesW
