Bonding Resin Pool
thefloatqueen
958
Columbus, Ohio
I made you a cute little diagram! Lol. Please note that the orange/brown lines are the pieces of copper wire connecting the loop to the various components!
And I totally am ignoring work that I brought home and should be focusing on, when I’d rather do this!
Edit: I didn’t see the directive to stop the discussion until after I posted this!
FINALLY!!!!! Something I can understand! You’re the best!
  • Love
Reactions: kellyfair
magiteck
552
Neenah, Wisconsin
I don’t know if bonding your wall also bonds your water, so we’ll get someone in here to answer that
Just to answer this question specifically - it does not. Because you have a liner in between the wall and the water, the metal wall is not in contact with the water, and so the water needs to be bonded separately.
RB67
2
PA
So once the loop is established and connected to the fitting from the water. Where is the next connection?
magiteck
552
Neenah, Wisconsin
There should also be a bonding lug on your pump. Then, unless you have other metal structures within 5 feet of your pool wall, you’re done!
RB67
2
PA
Thanks for the quick response. So, connect to the wall seam, the water and then the pump. All my supports and top rail are resin, so I'm guessing any other connections around the pool loop would be a mute point? I have no other metal structures within 5 feet.
magiteck
552
Neenah, Wisconsin
You've got it.
