- Jul 21, 2013
- 60,151
- Plaster
- Pentair Intellichlor IC-60
That running at a higher speed is the automatic priming of the pump then it reverts to its set speed.I am going to guess the latter. Although when pump first switches on it runs high for a minute or two before changing to a lower speed. But on my hand remote I never saw options of changing speeds.
A modern automation system lets you vary the pump speed for different times of the day; different speeds for the pool and spa; different speeds when devices are run like cleaners or heaters; and different speeds when you want more skimming.
It does not sound like your Aqualogic uses any of the VS abilities of your pumps.
You basically have expensive single speed pumps unless there is programming in each pump control panel.
