Blue Devil CYA test
jmcmd1980
112
Lake Worth/FL
Jandy Aquapure 1400
I was looking for an alternative to the Taylor CYA test, and ordered the blue Devil test. So far, I found this to be worse than the Taylor test. You need to use a lot of reagent for each test, the scale is not very informative, and I always seem to get a reading of 30 or 40, knowing I have more CYA in my water than that.
Anyone else have any experiences with this test?
Jim
Jim,
I like the Blue Devil (Sliding Dot) kit better than the ones that are in my TF-100 and now the TF-Pro Salt.
That said, they are all very subjective.. More like a shotgun, where close is close enough..
I think the key is to find the one that works best for you, and try to run the test the same way each time.
Reactions: Mdragger88
Jim,
Thanks for the reply, I think the Taylor test works best for me and is much more reliable. The blue Devil test always seems to read low in the 40 range no matter what I put in and the scale seems much more difficult to interpret as I’m aiming for the CYA 70 level.
I read the other attached previous discussions on this and get a sense of where to go.
Thanks again,
Jim
Reactions: Jimrahbe
The 2 Reagents aren't compatible if the Taylor 4088 "moveable dot" test Tube is used with the Blue Devil Reagent.
I ran some comparison tests with both reagents a few years ago. The results are in these threads :
