Hi all,
I'm not sure if this is the best category for this, but I think it may be.
My CYA is around 30% and I run between 2-3.5PPM FC. My CC is 0.
PH is steady at 7.6 and TA is 120 after a gallon of muriatic acid. My tap water has a very high TA and the pool is around 8500 gallons.
Pool is an above ground steel wall with vinyl liner and I use a solar blanket.
I'm using a Taylor 2006C test kit and I check the water daily, sometimes twice daily.
I've been using Walmart brand unscented 6% bleach in our pool and I have a very sensitive sense of smell and it kind of bothers me. No one else notices it but me. It doesn't smell bad, I just can tell there's bleach. I just asked a friend and he specifically said it didn't smell chlorinish or anything to him, it was great.
Growing up, my dad always used HTH powder in our pool which I believe is just calcium hypochlorite. I don't remember it bothering me like the bleach although it's been 20+ years so who knows. Maybe I've just changed.
There's no other issues that I know of. Everyone else loves the pool, the water is crystal clear and doesn't burn your eyes. I'm using between 8oz and 14oz of bleach in 24 hours depending on the weather I usually add at night after everyone is out so when people are actually swimming the level is closer to 2 ppm.
I'm wondering if I switch to calcium hypochlorite, will the pool water smell different vs bleach or will the results be the same?
What options do I have?
