- Jul 21, 2013
- 65,360
- Plaster
- Pentair Intellichlor IC-60
Running your ichlor 30 @ 25% for 14 hours a day generates 1.7 ppm/day in 10,000 gallons.
Turn it off. Then do an Overnight Chlorine Loss Test
Almost three yearsRich,
How old is the plaster finish?
When did the dark stain first appear?
Are there other dark discolorations in other parts of the pool?
It's not phosphates. I don't think that it's copper. It might be silver. Have you ever added silver based algaecide?
yea, I plan on doing that when I get home tonight.. I just hope my wife doesnt mind me raiding her vitamin cabinetTry vitamin c.
If the stains are isolated to the steps, you may be able to do that. But it would ideal to know why/how they got there to start with to prevent recurrence. If we rule out iron, dry acid would indicate copper (although doubtful, you never know), last would be organic (algae) ingrained stains. You could lay a tab/puck on the stain for about 5 min if not tried already. I couldn't recall.I’m almost wondering if it would make sense to just drain some water out and pressure wash the stains
forgot to mention I let the puck sit on the stain just like the dry acid and vitamin c before scrubbing... the pool store folks think it’s black algae which is why the black algae remover got rid of the stain last time and that my phosphates are too high which is why it came back...If the stains are isolated to the steps, you may be able to do that. But it would ideal to know why/how they got there to start with to prevent recurrence. If we rule out iron, dry acid would indicate copper (although doubtful, you never know), last would be organic (algae) ingrained stains. You could lay a tab/puck on the stain for about 5 min if not tried already. I couldn't recall.
Yes, and I can’t scrape any of it off...Have you read the article on Black algae?
Note the way to test is to scrape off some and smear it on a piece of paper, or something else white. If it is a greenish color, then it is black algae.
Black Algae
This guide provides a step by step procedure for eliminating black algae in your concrete or gunite pool. Read full post here.www.troublefreepool.com
Pool store gave me some granules you sprinkle on them and let it sit overnight with the pump off and it went away but a couple weeks later it came back.
I plan on stopping in Saturday to see if they still have it.. I will report backI re-read your entire post, and your very first post caught my eye. So you sprinkled something on the spots from the pool store, and they went away for a few weeks. Do you know what this "something" was?
Clearly that pool store stuff isnt a long term solution, but the stain reacted to it. Find out whatever the pool store stuff is, and it will help the experts here identify the true problem and help you fix it.
