Black stains just keep getting worse
Rich G
61
WPB, FL
Okay, so wanted to give a little update
I’ve done the following
Triple shocked the pool
Brushed twice daily with a stainless steel brush
Placed granular chlorine on the stains twice
Replaced the filter
Put in algaecide
So far the stains are almost all gone. FWIW I did a phosphate test and it didn’t register at all.
ajw22
19,434
Northern NJ
Rich G
61
WPB, FL
Just used three times the amount of shocked
This is the algaecide I used
What’s weird is I thought I always maintained my water, always thought I kept the chlorine too high so I’m not sure why this stuff showed up
What does that mean?
What algaecide? What ingredients?
Sounds like you had an algae problem. Glad you got it figured out.
Maintain your chemistry following the FC/CYA Chart
Rich G
61
WPB, FL
Just a follow up since you guys have been so helpful
I drain the pool enough to expose the sun step.
A pressure washer and even straight acid won’t touch these stains... it’s gotta be a defect in the plaster
