- May 3, 2014
- 62,717
- Fiberglass
- Pentair Intellichlor IC-40
Re: IC60 Cell Light Off
If you must have a test to confirm your CYA you can use the liquid stabilizer. Once introduced to the pool water it takes a short time to show. Circulation and quick brushing of the pool and you can test for it.
Realize that if you start with fresh water, 0 CYA, and you add a specific amount of CYA powder, it is in that water. As long as you dissolve it via a sock directly into the water instead of pouring into the skimmer, you should be able to test for it in 24 hours, if necessary.
There is no chemical reaction with CYA, so what you put in the water, is in there.
Take care.
Take care.
