Biting flies near the pool
wwerdna
51
Sparta, NJ
We have a terrible problem with biting flies by our pool. We suspect they're coming from the wetlands on the unowned land next to us and they can ruin time spent by the pool as they dive-bomb anyone swimming. Last year we tried the fly bags from Amazon that, while they obviously caught lots of other flies as emptying them was one of the more disgusting experiences in my life, didn't solve the pool problem. This year we're looking at an H-Trap as they get very good reviews, but they're relatively pricey so we don't want to throw money away if we can avoid it. Has anyone tried one of these near a pool? If so, how close to the pool do you put it - there's online photos of them right next to a pool, but surely the aim should be to catch the flies before they can even see us tasty humans?
kimkats
46,346
Tallahassee, FL
Are they yellow/deer flies? What we found that worked is kind of weird but it works for us:
-blue, plastic plates
-Tangle Feet make sure to go all the way down to the bottom of the page INSECT TRAP COATING 8OZ - Walmart.com
-fishing line
-rubber gloves
-cheap bowl scraper (keep it in a plastic bag after using it)
Poke a hole in some of the blue plates. Run the fishing line through the hole. Hang the plates about 10 or more feet from the pool. Use the scraper to goop the tangle stuff on both sides of the plate.
Do not wear good clothes as this stuff is STICKY and almost impossible to get off clothes.
I have done this for the past 3 yrs and had great luck with it!
Kim:kim:
Wobblerlorri
Just a note, the H-trap only works on the tabanid flies, meaning horseflies. I don't think it works on the smaller biting flies like deer flies.
You need to look closely at your biting flies to make sure you get a trap that will catch them.
here is an Amazon page with all kinds of biting fly traps. I'd several different kinds and hang them around the pool. Incidentally, there's a tabanid type trap that works on the same principle as the H-trap for only $28...
outbreak
52
Destin, Fl
-fishing line
-rubber gloves
Kim:kim:
That's close to what we do. We get a beach ball, spray paint it black, then use the spray tangle on it. Then we'll hang it somewhere close and they flies go straight for it!
zac280
53
Central Georgia
Making deer fly traps this weekend, they just seem to be worse than usual this year. My plan is to buy a pack of blue solo cups and coat them with Tanglefoot as Kim recommended. I'll hang them with fishing line in several places around the yard. The new version of Tanglefoot seems to have an integrated brush which is nice.
Reactions: jmikeb
bmoreswim
Platinum Supporter
6,410
Central MD
If you are looking for an insecticide, this is the product I've used for mosquito control and it works very well. I need to spray as I got bit like crazy the other night by the pool. I am also hoping to eliminate the thousands of clover mites (the tiny little red bugs the size of a "." on the hard surfaces around the pool. The 'insects controlled' list includes biting flies. I'm not crazy about using insecticides but this one also cover the tons of ants that will be invading my house any day now if I don't spray. You apply it with a pump sprayer.
Bifen IT
Reactions: jtpipkin
outbreak
52
Destin, Fl
You can buy the spray tangle at Home Depot. A lot easier...
jtpipkin
247
albany, ga
Bifen IT
That Bifen IT is some good stuff. Fired my exterminators years ago and just spray myself. Haven't had one issue. Use it in ant beds, they don't relocate, they dead ;) Spray the bushes with it and helps control mosquitos. One small bottle of that stuff makes gallons of spray, lasts for years. If a bug walks on it, they dead:)
Reactions: bmoreswim
Geebot
928
We picked up a Dynatrap from Costco. Supposed to work with mosquitos and biting flies. Has made a difference in our yard.
kimkats
46,346
Tallahassee, FL
I hang mine from tree branches at about face height for me making sure they can swing free without hitting any leaves or such. I have one on each side of the barn and two in the front of the house.
I use fishing line to hand the plates.
Reactions: jmikeb
