- May 23, 2015
- 25,733
- Plaster
- Pentair Intellichlor IC-60
No, I'd say it was closer to 7500. Not as low as I'd hoped, but getting the CH so low does help add to the time until the next refill (filling with tap instead would've started me around 400CH), which does save water in that respect.
My summation is that the service is great for people that want to save a bit of water (~30-50%), get higher quality water, but don't mind paying a bit extra as a trade-off.
Here's a softener question...would a softener help maintain the same level of water quality that is now in the pool? Specifically, would metals and other minerals in the tap water like iron or copper be filtered out by a water softener? Obviously calcium would be.
Softeners remove mineral hardness, so mostly calcium and magnesium. You don’t want a softener exposed to iron or copper as the bonding to the ion exchange resin will be irreversible for transition metal ions (Fe, Cu, Mn, etc). Typically when significant quantities of metals are present, one must use a special green sand filter for that.
But, a softener would maintain low calcium levels as the water from the softener has zero Ca or Mg in it. So if your pool had a softener hooked up to the auto fill, you would see no rise in your current calcium levels.
